Air Conditioner Filter
An air conditioner filter replacement can greatly increase your efficiency. You will find that an air conditioner filter will provide many other benefits as well, such as cleaner air, reduction in allergens, both of which reduce the symptoms of allergies.
The Purpose of the Air Conditioner Filter
The main purpose of the air conditioner filter is to keep the system components such as the blower and evaporator coil clean. Clean air is now getting more attention for the filters purpose. A dirty air conditioner filter or one that does not fit correctly in the unit can have negative effects on the system as well as on us.
• Reduced Cooling Affects
• Failure of The Compressor
• Lessens Equipments Life Expectancy
• Increases Blower Consumption
You should change the air conditioner filter in your home about every month or two and in business environments the air conditioner filter should be changed every couple weeks.
