Login Error
Close
Air Filter Comparison: The Go-to Guide
by DoItYourself Staff
Next time you buy a new air filter for your vehicle, you may engage in air filter comparison. The air filter provides clean air to the gas in your engine. Read this article to decide what filter is right for your car or truck.
Air Filter Overview
Changing your filter before your car's performance is in jeopardy is particularly important. Having a dirty air filter will not only decrease your car's performance, but will also increase its emissions into the environment. Most manufacturers recommend changing air filters every 30,000 to 60,000 miles, but these estimations can vary, based on your driving conditions. For the best results, check your air filter at every routine oil change.
Factory-Model Air Filters
A factory-model air filter is your best bet when replacing your car's air filter. Check your owner manual and work with a auto store associate to find the correct part to match your car's make and model. In most cases, you can find the correct part on hand at the store. Factory-model air filters are generally inexpensive and (except in the cases of rare car models) readily available at any auto parts store.
Aftermarket Air Filters
If you prefer a better filter, an aftermarket air filter may be the way to go. Costing a little more than a factory model, an aftermarket model will provide superior performance by a finer filtering system. More air gets in the engine with less debris, and your vehicle's performance improves.
Performance Air Filters
Performance air filters can be rather expensive. But they can increase the power and speed of your car.
Cost of Air Filter Replacement
For most people, cost is the leading factor in what kind of replacement air filter they will purchase. For the most affordable solution, a factory air filter is the way to go, followed by an aftermarket filter, and then the most expensive option, the performance air filter.
 forum activity
