cancel
Job type :
Zip Code :
community forums
comments
Air Power Tools
Air power tools use an air compressor instead of electricity to perform tasks. They are generally a lot more powerful than their electric counterparts and are used for many big construction projects. All air power tools require a specific PSI (pressure per square inch) to work. To change the PSI for your tools follow these instructions:
  • Step 1: Look on the tool or tool's case to find out what the required PSI is. If you cannot find it check the instruction manual or call the manufacturer.
  • Step 2: Adjust your compressor to the exact PSI required. There should be a small dial right on the air compressor for this.
  • Step 3: Attach the air compressor hose to your air power tools.
Special Cautions for Air Power Tools
Although they are very convenient, powerful, and immediately ready for use, air power tools pose a certain threat if you are not careful. All tools will usually require a different PSI level, and forgetting to change it while switching tools can be disastrous. Not enough pressure will cause the tool to operate slowly, or not at all. Having too much pressure can destroy air power tools.
member comments
Did-it-myself Projects
updated by gibburnz
did this on 11/23/2009
Small Kitchen Rental Upgrade
updated by Rocky1008
did this on 11/07/2009
Garage Shop Organizing
updated by dhammon
did this on 11/04/2009
The Deck
Your Winter Home Checklist
sponsored articles of the day
