Login Error
Close
All About Composite Bathroom Countertops
by DoItYourself Staff
The use of composite material for bathroom countertops, is a very popular alternative to the use of natural stone or granite. Composite bathroom countertops are now a preferred option by designers and architects, because of the versatility they offer. They are also comparable to natural stone when it comes to durability and versatility. Not to mention, They have a very competitive price.
Composite is a man-made, solid material, that is a mixture of natural minerals and pigments, bound together by acrylic, to make a stone-like product. In other words, it is a kind of high quality plastic. Some are predominantly acrylic, while others contain polyester plastic.
In choosing a composite bathroom countertop, inspect the specification sheets for the product's composition. Those with high acrylic plastic composition are advisable picks.
Quality and Function
The first thing that you are probably interested in is knowing if this material is durable. Contrary to what some people think, it is actually known by experts to be very durable. It is also impact resistant. And because it is non-porous, it does not absorb water or moisture. There is no need to worry about water infiltration, that could later cause damage and decay.
Composite bathroom countertops are also easy to maintain and repair. The usual solid surface cleaners can be used to remove common stains. Scratches can be removed by buffing or through sanding. You can also refinish their surface - to have either a matte or glossy finish. This can be done at home through simple do-it-yourself steps.
One disadvantage, however, is that this kind of material can get damaged with excessive, concentrated contact with extremely high temperature.
Design and Versatility
Because it is a high quality kind of plastic, it is also formable into countless number of form and shapes for bathroom countertops. This allows for multiple countertop edge profile options. This flexibility also makes it a good complement to other bathroom features.
One of its remarkable qualities is its ability to merge seamlessly with other bathroom components, like your sink and your wall. The material allows for this, without any trace of seams, or even the tiniest gap where water can pass through.
Since it's completely solid, whatever design it has is consistent throughout the material. Furthermore, it has the widest variety of patters, colors, and textures to choose from. Composite bathroom countertops can mimic the appearance of natural stones, wood grains and other contemporary patterns and textures in demand in the market. If you are a meticulous designer, you have an array of designs to choose from, complementing or accentuating virtually any bathroom interior motif.
Because this material varies in ingredients, composition and appearance, if you check manufacturers’ stores or websites, you will come across numerous kinds of composite countertop headings or categories. Some of these would be solid surface, artificial granite, pure acrylic, composite acrylic, artificial quartz, artificial marble, and resin.
Choosing a Product
Because of the numerous choices, you might find it difficult to decide which one will suit your bathroom needs. Consider these guidelines when canvassing through different composite bathroom countertops.
First, know your budget and work around it. Second, opt for the higher quality composites, with more acrylic in their composition. Third, complement your bathroom motif and design. And lastly, canvass stores for the most competitive price.
 forum activity
