All About Concrete Screws
Concrete screws are a necessity when it comes to securing anything to concrete. Other screws are unable to do the job that a concrete screw can; they are very strong and are able to go through concrete, no matter how thick. There are several things that you will need to keep in mind when it comes to concrete screws. They can be a hassle if you do not know how to work them, either before or during use. Know the necessary steps to take in order to properly use concrete screws.
Removal
There may come a time when you will need to remove the concrete screws. This is not a difficult task, even if the concrete screw has been stripped. Using a drill, attach the screw remover bit. Be sure that you make the drill spin counterclockwise in order to loosen the screw. The bit will need to be firmly pushed into the screw head. From there, you will simply need to remove the screw from the concrete.
Inserting
Concrete screws work by creating their own thread into the concrete. It is important that you read the instructions on the concrete screw kit. This will tell you the exact depth that you will need to have, making the job much easier. There is a depth gauge that you will be able to use for this. You will need to be sure that you have the screw aligned just right before you attempt to insert it. It is important that you do not over tighten the screw. This could cause damage in the threads, which could result in the screw breaking entirely.
Types
There are several different types of concrete screws. They all depend on the type of job that you have and what you expect out of them. Be sure that you are aware of the size of the concrete screw that you will need, as well as the thickness and length. These are important factors when it comes to getting the job done.
There are pull out, masonry and shear screws. Each have their own perks and drawbacks. If you are ever in doubt, go to a hardware store and ask the advice of the employees or simply go online and search for each screw.
