Login Error
Close
Alternative Exterior Ceiling for a Modern Look
by DoItYourself Staff
If you have an outdoor space that you'd like to spice up in some way or to make more unique by adding a roofing cover to, you should consider installing an exterior ceiling. These can be opened up enough so that the space still feels like it's outdoor, but they can provide helpful protection against wind, rain, snow and other elements as well. Best of all, they can help to also change the look and feel of your ceiling and outdoor space significantly, to provide you with a new style and design aesthetic to work with. Read on for a few ideas of alternative exterior ceiling types.
Bamboo Mesh
One of the more popular options for an exterior ceiling is bamboo mesh. It's a great choice for an exterior ceiling because it doesn't matter if the mesh itself becomes ever so slightly damaged over the course of time; this will be far less noticeable outside than it would be inside. Furthermore, the use of a natural product like bamboo out of doors helps to keep your outdoor enclosed space feeling natural and fresh. Bamboo is also an environmentally sound and renewable resource, meaning that you won't need to feel badly about using it for your ceiling as well.
Ceramic Tiles
Ceramic tiles are another great choice for an alternative exterior ceiling cover. These tiles will provide you with a solid cover and protection from the elements. They can also be used to create any number of different stylish designs; the options for the appearance of your ceramic tile roof are virtually limitless, given the huge array of different colored tiles and designs from which you can choose. You can also mix and match designs in order to come up with the best look for you and your outdoor space needs. Finally, ceramic tiles are easy to install and are very durable, which is a great quality to look for in an exterior ceiling material before you begin working.
Stucco
Stucco is a type of plaster and concrete that provides a rock-lick appearance without the extreme costs of many types of rock. It can be very difficult to come up with a unique piece of stone that will work for a ceiling space, and oftentimes these stones are far too heavy anyway. Stucco is a great alternative, then, because it provides you with a wide range of different color and style options while retaining a cheap cost and an easy installation procedure. It has a smooth and professional look to it as well, which many people find attractive and desirable for their exterior ceilings.
For additional ideas of items and materials to use for your exterior ceilings, or for more information about how to select these items and purchase them and install them, consult with a home improvement specialist and an expert in your area. They can help you to sort out exactly which will work best for your needs and budget.
 forum activity
