Alternatives to Propane Fireplaces
Propane fireplaces have become very common in the United States today. Many Americans found the use of propane fireplaces ideal and convenient for their homes. As compared to conventional fireplaces, propane fireplaces require less maintenance and make less mess. Propane fireplaces are known for their use of propane instead of wood. The use of propane makes the fireplace cleaner as compared to previous options. Propane fireplaces do not produce ashes or soot and the only downside to these fireplaces is that propane can be costly. The foreseen increase in the price of propane pushed for the development and search for alternatives. Currently there are several options seen as alternatives.
Heating Systems
Solar heating systems are considered as possible replacements or alternatives to propane fireplaces. This kind of heating system can either be active or passive. Passive solar heating systems invest on the design to amass and hold daylight. Homes with passive solar heating systems have huge windows with thermal mass surfaces. The windows should be facing in the southern part for the system to work. The thermal mass used in passive solar heating systems refers to an absorptive material. The absorptive material ranges from concretes, tiles even water. The primary function of the material is to collect and store heat. Heat stored in the panels is reserved for later use. There are two options when using thermal material: to incorporate them in the walls or in the flooring systems.
Active solar heating systems work in a separate manner. This kind of heating system use solar collectors, exchangers, heat pumps, storage tanks, as well as controls to collect, transport, and distribute heat in a specified area. In order to transport store heat from solar collector throughout an area, electricity is necessary.
Passive and active solar heating systems use the sun to warm the house and provide hot water. Many experts commends solar heating systems. Basically, both kinds of heating systems have no harmful emissions. When implemented, they can be also very economical.
Geothermal Residential Heating Systems
This kind of heating system use heat from the Earth to provide warmth for homes. A piping system is installed underground to absorb heat. Fluid is included in the piping system to make sure that heat is stored. The idea behind Geothermal Residential Heating systems is that the Earth’s temperature is constant below the ground.
The fluid in the pipe is pumped into the home. There is a heat exchanger in the system ready to extract the heat from the fluid. Afterwards, a fan distributes the heat. There are several advantages in using Geothermal Residential Heating systems. It’s extremely safe, quiet and totally efficient. A house’s ductwork can be used for the system thus it will automatically fit any home. In the same way as solar heat systems, the source of heat used in geothermal heating system is renewable and does not deplete.
Other alternative heating systems include pellet stoves and fireplaces using corn. As efficient as propane fireplaces are, the use of propane proved to be problematic in the future thus the emergence of new heating systems.
