Login Error
Close
Aluminum Siding Benefits
by DoItYourself Staff
Aluminum siding is popular for many reasons. It is cost effective, attractive, and durable. Here are a few more of the benefits associated with aluminum siding.
Durable
Aluminum siding is probably most popular because of its durability. When maintained you can expect the siding to last forty years or more. Any damage from scratches or corrosion can usually be fixed simply by sanding and painting the affected area. Dents can generally be removed easily as well. If you have an area that is badly damaged you can just replace the section that’s damaged as opposed to replacing the entire exterior.
Cost Effective
Aluminum siding is extremely affordable. Many other types of siding can cost up to 80% more than aluminum. Installing aluminum siding can generally be done in a day, and is inexpensive compared to other siding installation types.
It Can Be Updated
Unlike vinyl siding, aluminum siding can be painted. This is an easy way to update your home's look without spending a lot of money. Aluminum can also be replaced in sections. If you choose to replace your aluminum siding this can be a great time saving feature.
It Can Be a Do-It-Yourself Job
Aluminum siding can generally be installed by yourself with just a few tools and some time. Most siding manufacturers will have complete instructions and tool kits available for you.
If you are adding new siding to your home, look into all the options available and don’t discount the idea of aluminum. It can be a great addition to your home.
 forum activity
