Login Error
Close
Aluminum vs Steel Garage Doors
by DoItYourself Staff
Aluminum and steel garage doors have their good and bad points. Here’s a guide to help you decide on what type of garage door to use.
Durability
Steel doors are more durable than the aluminum type. Aluminum is a softer material and can be easily dented by strong winds or harsh weather conditions.
Price
Garage doors made of aluminum are definitely much cheaper than those made of steel. If you are on a tight budget, you may want to pick the aluminum variety to save on costs. However, finding replacement parts and units for aluminum garage doors can be difficult because they are not as popular as garage doors made of steel.
Maintenance
It is easier to maintain aluminum doors because they do not corrode and rust when exposed to moisture. With steel doors, you need to repaint them occasionally in order to keep their beautiful appearance. If you live in humid areas or regions near the coast, it would be better to choose aluminum over steel doors.
Operation
Since steel garage doors are heavier, they are harder to operate manually. So, if you are not planning to install an automatic door operator, you should choose an aluminum garage door because it is easier to open and close manually.
 forum activity
