Analog vs Digital Pressure Gauge
A digital pressure gauge gives accurate pressure readings of gas, air, fluid or other matter. The device is available in various shapes and sizes. Prices range widely, which caters to the different needs of consumers. The digital gauge is a more modern device amongst pressure reading systems. Analog gauges, although older, also continue to be widely used. Pressure gauges are used heavily in manufacturing plants, industrial settings, automotive industry and construction. They also form a vital tool in the health industry. How do the two compare? Below are the advantages and disadvantages of each.
Advantages of Analog Pressure Gauge
Several types of analog pressure gauges can be found on the market. Bourdon tubes, capsule elements, diaphragm elements and bellows are some of the analog gauge varieties available. They generally cost less than digital pressure reading systems. This puts them within the reach of consumers who may not be able to afford the digital type. Analog gauges produced for health purposes are usually fitted with a stethoscope. You need not buy a separate stethoscope. This gives the gauge a higher efficacy. Accuracy is higher with analog gauges than the digital type. You can visually determine exactly where the dial falls although it may take some effort separating the hashes.
Disadvantages of Analog Pressure Gauge
Reading calls for some effort due to the hashes involved. One must determine precisely where the arrow falls. More time is also involved in taking pressure readings. You must allow some moments for the dial or pointer to settle on the figure. If you have to read the pressure in a hurry you may not get an accurate reading. If you have eyesight problems, analog gauges are likely to cause strain during pressure readings.
Advantages of Digital Pressure Gauge
Digital gauges aren’t complicated to operate. It is easier and quicker to read digital gauges than analog gauges. Pressure is indicated in a simple and reliable format. The pressure determined by the gauge is automatically displayed on the screen. You need not trouble yourself with counting of hashes. Various shapes and sizes are available on the market. This gives the consumer a variety to choose from.
For some consumers, getting a gauge that will blend into a certain scheme is important. Health facilities, for instance, or automobile showrooms may prefer gauges that add to the décor. Digital gauges give one more choice where décor factors. Digital gauges have a higher performance level than the analog range. Durability is also higher for digital gauges. They have fewer parts than analog gauges which makes them a low maintenance device. This adds to their overall convenience.
Disadvantages of Digital Pressure Gauge
Digital pressure gauges cost more than the analog type. Although various sizes and shapes are available on the market, pricing is higher. They also require batteries to run. This adds to their overall costs. They can cause you inconvenience should the batteries run low when you don’t have a spare set. It could disrupt an urgent activity.
