Knowing how to properly care for and maintain an antique ceiling fixture, will ensure that a piece of history lives on. These are some tips for keeping your antique working well.
Replacing the Wiring
Wiring is often the first thing stop working properly in antique ceiling fixtures. It gets old, and usually isn't replaced as often as it should. By replacing the wiring, you can be sure that the antique ceiling fixture will work longer.
Taking Care of the Metal
Waxing is an important way to care for any type of antique furniture; ceiling fixtures are no different. Waxing the metal will help seal it from the air, and any other possible particles.
Taking Care of the Accessories
Certain things, such as wiring and metal, are crucial to the function of the antique ceiling fixture. Smaller things, such as screws, crystals, and other accessories, are often overlooked. Keeping these clean is an important way to maintain your antique fixture. Making sure that all of these accessories are in good condition will improve the overall condition of the fixture itself. Be sure to replace the screws when they become stripped, rusty, or old. Wash the crystals, making sure not to scratch them.
Using the Right Light Bulb
Using the right light bulb is an important way to maintain the antique ceiling fixtures in your house. If you use a light bulb with higher wattage than the fixture is built for, it can damage the fixture's wiring. While you may want stronger light bulbs, resist the urge to test it; simply add another light to the room.
Following all of these tips can help you to increase the life of your antique ceiling fixture. While maintenance may take some time, having these antique fixtures is well worth the trouble.
Questions of a Do It Yourself nature should be submitted to our
