Login Error
Close
Applications of a Sloped Ceiling Recessed Lighting
by DoItYourself Staff
Sloped ceiling recessed lighting is the installation of recessed lighting into a ceiling that slopes. This may be an appropriate and useful way to light a room that has a ceiling configuration that may not otherwise allow or permit any other types of lighting to be installed. Recessed lighting in a sloped ceiling should be something that is planned for by an interior designer or lighting consultant and installed by a qualified and licensed electrical contractor. This will ensure the proper installation of your sloped ceiling recessed lighting, and give your room the proper lighting that it needs.
What Recessed Lighting Is
Recessed lighting is the type of lighting designed to sink into the ceiling of your home. This does away with the need for light fixtures or lamp covers that can be unsightly or take away from the design aesthetics that you're looking to achieve in the room. In most rooms with a normal flat ceiling, the installation of recessed lighting does not pose many problems or concerns for the home owner. In the case of a sloped ceiling, the installation of recessed lighting may pose more challenges. These challenges include the proper placement of the lights to ensure that light coverage is sufficient.
Recessed Lighting as a Lighting Solution
In comparison with other lighting choices that may be available to a home owner in a room with a sloped ceiling, recessed lighting poses one of the better solutions. It is much easier to maintain recessed lighting from a cleaning standpoint than it is to keep and maintain other types of lighting applications. The light bulbs used in recessed lighting fixtures tend to be more energy efficient, requiring a need to change them less frequently than a room that does not have recessed lighting installed. This translates into a lower energy cost to light a room than in one does not use recessed lighting.
Installation Costs for a Sloped Ceiling
The installation costs for recessed lighting in a sloped ceiling room varies depending on the labor costs for your region as well as the amount of slope in the ceiling. A ceiling with a greater slope to overcome by the installation team will cost more to have recessed lighting installed than a room that does not. These issues can be determined when a lighting or design expert surveys the room and makes a determination as to how the lights will be installed, and the cost to make the recessed lighting design happen.
Obtaining Design Ideas
Design magazines and home builders can be a good source of information, as well as lighting and electrical contractors. These groups and individuals can show you the many applications that can be derived through the installation of recessed lighting within your home and in your sloped ceiling. This information can help you determine the cost and benefit of having recessed lighting placed into your sloped ceiling.
 forum activity
