Login Error
Close
Applying Faux Paint to Bathroom Cabinets
by DoItYourself Staff
what you'll need
  • Sandpaper
  • Latex semi-gloss paint in your choice of color
  • Paint brushes
  • Sponges
  • Paint tray
  • Paint roller
  • Top coat or glaze
  • Drop cloths or old newspapers
  • Old clothing
  • Old rags
  • Tools for making textures: combs, dusters, scrub brush, string, linen, old fabric swatches, forks, spoons, gauze strips; or any typical household items.
One of the best ways to update your bathroom is by changing the bathroom cabinets. Faux finishing techniques can transform a cabinet without requiring the removal of the cabinet itself. Faux finishing is creating a type of surface that resembles the real thing like wood, denim or suede. You can create most finishes with simple household items and paint. The items used to create the finishes could include combs, feathers and sponges. Here are some easy steps to help create interesting and beautiful faux finished cabinets:
Step #1: Prepping
Begin by sanding down old paint on the cabinets. Clean them off after the removal process and fill any chips or cracks with wall plaster. Be sure to use the appropriate type of plaster for your type of material.
Prepare and mix paint in the paint tray and put down drop cloths or newspapers to protect flooring. Also, put on old clothing to protect yourself.
Step #2: Basic Paint
Start by painting over the cabinets with a base coat of semi-glass paint. Use the paint roller and move from top to bottom. Depending on the paint manufacturer’s instructions, you should wait at least 24 hours before attempting the faux finish treatment. Wait one full day to allow the paint to thoroughly dry.
The next day, paint the next color on your cabinets. Paint from top to bottom and let the paint dry until it is sticky to the touch.
Step #3: Tooling
Take your tool and begin faux painting. Be creative and imaginative. For example, use a sponge and start using it on the paint to create a pattern. Be sure to use concise patterns and pressure so that your technique shows up well. You can take classes for technique procedures at many home improvement stores.
Official faux finishing tools can be purchased at home improvement and paint stores. However, you can also find what you need just sitting around the house. A feather can make light strokes, while rolling string can create interesting lines and using a scrub brush can also make lines for a rugged distressed look. Let the paint dry over night.
Step #4: Glazing
Using a clean paint brush and paint a thin layer of clear glaze to seal the work. Let the cabinets dry before opening them. Allow at least one day for glaze to dry. Be sure to use a glaze that resists mold and mildew. Once you are finished, clean up and store materials away from pets and children because paint and glaze is toxic and hazardous to your health.
 forum activity
