cancel
Job type :
Zip Code :
community forums
comments
Green and Budget-friendly Ways to Improve Your Yard
Green and Budget-friendly Ways to Improve Your Yard Landscaping evokes visions of dollars and debt, but it doesn't have to leave you pining away for a nicer yard. With just a little bit of cash and good weekend or two of hard work, you can transform your outdoor spaces. Rethink what it takes to make your yard more hospitable, because it really doesn't take as much as you think.
You'll make the most impact in your yard by simply cleaning up what's already there. This will take some time, but doesn't have to be expensive. Rake up stray twigs and leaves, put all the rocks back in their place, and trim the bushes and trees. With the excess growth out of the way, you can take a fresh look at your yard and decide what to do from there.
Use "people-powered" tools
What are the costs of yard clean-up? It doesn't have to be that bad. Rather than buying the power leaf blower, hedge trimmer and weed whacker, invest in a good set of manual tools that can cost much less. They just require a little work -- consider it your weekend workout. A good pair of hand trimmers can make quick work of those overgrown shrubs, and tidy up the borders of your grass. Believe it or not, you can still get a hand edger at any hardware store; the first time might take a bit more work, but if you stay on top of it, edging can be a simple bi-weekly touch-up.
The best part about using people-powered tools is the impact on the environment, or lack of impact. Even electric leaf blowers have their carbon footprint because so much electricity is still supplied by power plants that aren't as green as they can be.
Plant inexpensive annuals
By now, most garden centers have a great supply of impatiens, marigolds and begonias. While some varieties can be pricey, like New Guinea Impatiens, select the hardier "base model" impatiens instead. Keep it simple to make a positive impact on your budget.
Not sure what flowers to choose? Take a look at your yard. Where will you put the flowers? Next, take a day to check out how much sun that spot gets. If it's sunny all day long, stick with the marigolds. If it's shady all day, the impatiens are your best bet. Somewhere in the middle? Begonias.
When planted in the right areas - meaning getting the right amount of sunlight - these plants don't require large amounts of water to stay healthy. However, there are some perennials that require even less water -- check out daisies, day lilies and peonies.
Planting a flower bed doesn't have to be hard, either. Once you figure out where you want the flowers to go, you know you have to get out the shovel and remove the grass that's already there. Shake out any excess dirt from the clumps of grass, and put the grass in a yard waste bag. Loosen up the soil, then smooth it back out with a plain old garden rake. It should be loose enough so that you can use a hand trowel (a tiny shovel) to make holes for the plants. After taking the individual plants out of the temporary containers, pull a little at the roots to loosen them up. By "tickling the roots," you encourage them to spread out after planting. Plop them in the hole and backfill the hole with dirt. Water well, and you're done.
Use "natural stuff" to feed your yard
Composting isn't hard at all and it takes very little cash. Some people designate an area by simply calling it their compost pile. Gather leaves and other dead organic matter from your yard in one pile. Add some kitchen scraps, like fruit and vegetable peels (never meat or dairy), mix it all up and let it bake. After a few weeks, mix it up again. You can use a shovel, a garden rake, or spring for a pitch fork for this job. Keep a casual eye as you turn it every few weeks. Soon you'll see moist, dark soil emerging. Once you have a good mound of compost, add it to your flower beds in a thick layer. You can even get that garden rake out again and mix the compost in with the soil already in the flower bed. The compost will provide beneficial nutrients to the plants, and you avoid chemical fertilizers.
Here's your list of tools so far:
* Shovel
* Pruners
* Hand loppers
* Hand trimmer
* Garden rake
* Yard rake
* Pitchfork, if you feel like splurging
Check out your yard. By now you've purchased some gardening tools that you'll use for years to come. You've purchased some annuals and maybe some perennials. So far, you haven't spent more than a couple hundred bucks. You got some exercise, and reduced carbon emissions by not using power tools. Next, take a look at your finances and see if you have the cash to do more. From here, you're adding things to your yard that make you happy, and improve the look of your yard and add value to your home.
Make Improvements to Your Home Today - Get Cash-Out Up to 95 percent by logging on to www.quickenloans.com.
Copyright © 2008, ARAnet, Inc.
member comments
Did-it-myself Projects
updated by Rocky1008
did this on 11/07/2009
Garage Shop Organizing
updated by dhammon
did this on 11/04/2009
The Deck
updated by dannyboy00
did this on 10/17/2009
Custom Front Porch
Your Winter Home Checklist
sponsored articles of the day
