cancel
Job type :
Zip Code :
community forums
comments
An Arbor can add Style and Value to Your Yard
by Murray Anderson
When warm weather arrives we all want to spend time outside enjoying it. However, in the spring we sometimes forget about those hot sticky days in the middle of summer, when the idea of sitting in the sun can be anything but pleasant. One solution to make your yard a more pleasant place to spend time is a garden arbor. Defined by the dictionary as a shaded structure usually covered with shrubs, vines or vegetation, an arbor can provide a pleasant and attractive respite from the heat of the summer sun.
Arbors aren’t just attractive additions, they can be functional as well. You can position an arbor to provide an elegant entrance to your yard or create traffic patterns and guide people to features in your garden. An arbor can also serve to break up your yard into separate “rooms” or areas and expand your useable yard area out beyond your deck or patio. Finally an arbor can provide some privacy in your yard and free you from neighbors in overlooking homes or building.
Choosing your arbor
To figure out the arbor that’s right for you, you need to take some things into consideration.
  • How do you want to use your arbor? For example, is it purely decorative or do you want it to have a truly functional use and provide a shady place covering a bench or a small patio set to escape from the sun.
  • Where is the best place to locate it? Is it a destination in itself or primarily a visual element in your garden?
  • Do you plan on having shrubbery or vines climbing over the entire structure? Location may determine the type of plants that will near your arbor.
  • You want to consider the architecture of your home when choosing the style for your arbor. If you have a traditional home an arbor with classic lines would probably fit in best while a Victorian style home would demand a more ornate arbor design and a cottage or country style home would be enhanced by an arbor with solid straight lines.
What about materials?
  • Arbors can be made from all kinds of materials. Traditional wood, vinyl or metals like iron or even copper can all make beautiful arbors.
  • Wood has the obvious advantage in that it’s relatively inexpensive and very adaptable. However, wood (even redwood and cedar) does require some annual maintenance to retain its good looks. Many folks like to choose an arbor that’s low maintenance and easy to keep looking good over time. Vinyl manufactured to look like wood is a good compromise in some situations, since you get the advantage of virtually no maintenance while still enjoying the appearance of wood.
  • Build it yourself, from a kit or buy readymade
  • For most of us, if we’re building and arbor, it’s going to be made from wood. Depending on how elaborate you want the finished product to be that can mean building from scratch or buying a kit containing all the required pieces precut and ready to assemble.
  • Before you start to build your arbor, you should check local building codes as well your local homeowners association. Although a free standing arbor is unlikely to be an issue, you’re better off being sure it’s not a problem before you go to the trouble and expense of actually building it.
Here’s a final thought on adding an arbor to your yard.
Real estate experts say attractive landscaping can add 15% to 20% to the resale value of a residential property, so the arbor you install to enhance your enjoyment of your yard can actually have a real world financial payback. Isn’t it nice to know something you enjoy can also provide real value?
Murray Anderson is an experienced freelance writer over 500 articles published on the web as well as in print magazines and newspapers in both the United States and Canada. He writes on a wide range of topics and is a regular contributor to DoItYourself.com.
member comments
Related Articles
Cutting Edge Features Take Outdoor Power to New LevelCutting Edge Features Take Outdoor Power to New Level
A buyer's guide to some of the upscale features on newer lawn mowers and garden... read more
Instant Curb AppealInstant Curb Appeal
Ways to improve on your home's appearance in a hurry and on a limited budget... read more
Maximize Your Home's Curb Appeal
Maximizing your home's curb appeal can renew your home's appearance while raising its market value... read more
articles we like
DIY Landscaping Gravel
Many times landscape gravel is seen as underlying foundation or as a temporary fix but... read more
Personality of Scorpio
Scorpio, the Scorpion - October 23 to November 21... read more
Revive Your Rainy Day Fund. Refinance Your CarRevive Your Rainy Day Fund. Refinance Your Car
Living from paycheck to paycheck can be very stressful when unexpected emergency situations happen. When... read more
sponsored articles of the day
diy centers
