Architecture: Interior Design Partition Options
When you need to divide rooms in your house, you should first know a little bit about architecture interior design. Partitions are a smart way to create room separation without the extra expense of hiring a contractor to build walls. These partitions can also offer temporary solutions, where the configuration can be changed back to the way it originally was, at any time.
Know well the Space You Intend to Divide
You’ll first need to figure out what space needs to be divided, if you plan on splitting up an existing area. What you should be looking for include columns, places where there are sprinkler heads exposed, chair rails, windows, and any other obstacles that might interrupt the operation or installation of partitions. Be sure this area has all the materials needed for the activities to be done there. Before you do any work, simply stand and look it over. Is the lighting sufficient? Is there enough heat? How is the ventilation? Is electricity accessible? If any of these needs are not met, you may need to reroute some mechanical services.
Determine Necessary Support
Partitions are most often supported by a structure’s overhead. Therefore, examine the ceiling to be sure it contains no obstructions where the partition will be. In some instances, you might need the advice of a professional designer, if you suspect inadequacy in this support. If there isn’t enough support, you might want to consider floor supported models and portable partitions, or even a self-supporting system that does not have need for overhead structure.
Determine the Number of Partitions Needed
Next, figure out the number of partitions you will need, as well as their size.
Consider the Room’s Activities
Activities determine the sound control needs. The sound needs of a study, for instance, are far different from what’s needed for a band room. Therefore, higher acoustical ratings make for higher priced partitions.
Consider Storage Space
Where you want to store partitions is taken into account when configuring partitions. In other words, plan ahead where you want to store your partitions when they’re not being used. If there isn’t enough space in the room, thy can always be relocated to a different room. Panels can also be placed parallel with walls, as well.
Think About Special Finishing Needs
If you plan to finish your panels, decide on the colors that will go best with your room.
Will You Need Special Walls?
If this partition is used for a child’s room, or an at-home school room, you may consider getting partitions that double as chalkboards for this special purpose.
Meet Local Building Codes
Always be sure you know your local building codes before you invest time and money into partitions. For instance, hallways created via partitions might need to be fire code compliant.
There are many options when it comes to putting up partitions. But there are also important considerations, as well. If you plan well, and know your options, partitions can be a great addition to your home or office. The above information should help you decide if interior partitions are right for you.
