Login Error
Close
Are Space Heaters Effective Basement Heaters?
by DoItYourself Staff
Space heaters are one of the most popular and straightforward ways to heat up your basement. But are they the most effective? Here we'll examine the pros and cons of space heaters for basement use, as well as what alternatives you may have.
When Space Heaters are Effective
Space heaters are readily available in a lot of sizes. Massive space heaters are available to keep your big basement cozy, and small units can be found for preventing a bathroom chill. They are also very affordable and easy to use, making space heaters the go-to option for many a chilly homeowner.
When They are Dangerous
Like any gas powered heater, space heaters require significant ventilation. If your basement has no openings to the outside and you keep a space heater on overnight, you run the risk of carbon monoxide poisoning and even suffocation. Space heaters can also present a fire hazard, though modern units should not be too much of a risk if properly set up.
What if a Space Heater Won't Fit the Bill?
Space heaters are a great way to heat your basement if you take the proper safety precautions. But if proper ventilation isn't feasible, you can purchase an electric heater instead. However, electric units do use far more energy and may be inefficient for long term use.
 forum activity
