Login Error
Close
Are there different types of pellet stove pipes?
by DoItYourself Staff
Pellet stove pipes are an integral part of installing a pellet stove. For safety and proper burn, a pellet stove needs a pipe, available at any do-it-yourself stores or home center. Pellet stove pipes come in straight lengths and can be purchased according to the length you need. These pipes also have elbows available so you can control the direction the pipe goes to avoid walls and other obstacles.
Most pellet stove pipes are made of metal of varying thicknesses and grades. The heavier the pipe, the more it costs. Be sure to check with local codes to be sure you are purchasing a type that is approved for safety in your area.
 forum activity
