Are Wire Nuts Necessary?
Wire nuts, or twist-on connectors, are a faster and more convenient way of connecting wires and at the same time shielding them from being touched when power is flowing through them. They are not, however, the only types of electrical wire connectors. If you plan to connect 2 or more wires, you should consider some of the characteristics of wire nuts and how they compare with other methods of wire connection. Refer to the information below.
Wire Connection Alternatives
Wire nuts can be used to connect wires in both high voltage systems and in low voltage systems. In both these systems wires can be connect by soldering, but this method of connecting is not only more time consuming, but to disconnect the soldered wires it will be necessary to unsolder them or to sever them. Low voltage wires, typically used for electronic devices, are more often connected on terminal blocks that are neater, can be tested for voltage more easily and quickly, and are more neatly organized than with wire nut connections.
Wire Nut Operation
These twist-on connectors are named for the way in which they are used. The technician using these connectors first strips from the electric wire any insulation up to 1/2 inch from the tip of 2 or more wires. He then can twist the wires together and insert them into the wire nut and twist the nut to tighten and secure the connection. The nut is cone-shaped with metal threads inside the nut, making it possible to draw the wires further into the nut as the nut is twisted around the wires. Optionally, the technician may insert the stripped and untwisted wires into the nut without the wire being twisted.
Wire Nut Safety
By twisting the wire nut with stripped wire inserted into the nut, the technician not only connects and secures these wires from being accidentally pulled loose from the nut, but keeps the bare wires from being exposed where others may otherwise touch them and become injured from electrical shock.
Wire Nut Characteristics
Because wires twisted together and connected by wire nuts may be of different sizes, or gauges, and may have more than two strands of wire to connect, wire nuts are manufactured in a variety of sizes. These nuts, manufactured typically of plastic, are most often color coded to designate the size of the corresponding wire nut. They are also designed to be applied by hand, rather than by machine or tightening tools.
Wire Nut Restrictions
Wire nuts are designed to be used generally for connecting copper wires. They are not recommended to be use on aluminum wire. Why? One reason is that aluminum wire expands and contracts when subjected to thermal loading, loosening certain types of connections such as those made with wire nuts. In addition, connections made by twisting the wire create a torque that can damage the wire if the torque is too high. In addition, aluminum wire twisted together can overheat. Neither is aluminum-to-copper connections advised for use with wire nut connectors.
