Art Mural
If you want to give a room a truly unique, custom look, then incorporating an art mural is a great solution. Whether you choose an elegant art mural or one that is whimsical, it is sure to be a focal point and conversation piece.
How to Create Your Own Art Mural
Creating an art mural can be very pricey if you hire a professional painter. There are ways to effectively incorporate an art mural into your décor with out spending thousands. The following are some ways that amateur artists can create an amazing art mural.
Using stencils is a great way to create an art mural if you’re painting skills are minimal. Before applying the art mural to the wall practice on a painted board. Look carefully at proportion and dimension. An art mural looks best when the size of the objects are appropriate to the space and the items you paint don’t look flat.
You can readily find do-it-yourself art mural kits that take much of the guesswork out of your project. Often these art mural kits come with templates, transfer paper, and paint guides included. Typically you will need to purchase your own paints and brushes, the kits will usually tell you what you will need for the art mural. To get the best results when using an art mural kit, use it as more of a guide that an exact design. Changing up the patterns a bit will ensure your art mural is truly customized and looks like it was done by a professional.
