Asbestos Removal Cost Estimation
If you are renovating your house or are moving into a new place that needs rebuilding, asbestos removal will be one of the many procedures you will probably have to undertake. There are a number of other reasons for completing asbestos removal, with health concerns coming at the top of the list. Studies and scientific research have found that inhaling asbestos particles (highly carcinogenic in nature) over time is known to be a significant cause of stomach and lung cancer, and individuals exposed to the material run a potently high risk of developing the disease. Generally, asbestos removal is advised against because when the chunks of asbestos are ripped off they cause tiny particles to be released into the air, posing a health and environmental danger. However, you can contact a specialist agency to do the task if you have made up your mind regarding getting rid of the asbestos. Removal costs vary from state to state and are usually governed by regionally specific regulations and laws.
Points to Consider Prior to Undertaking Asbestos Removal
Since asbestos removal is a regulated procedure and a potentially dangerous one, it is mandatory that it should be carried out by only trained personnel who specialize in it. Being able to remove the asbestos without allowing the material to release into the surroundings and pollute the nearby area involves an advanced level of skill and expertise that cannot be achieved by laymen. Even though the market is flooded with Do It Yourself home kits for asbestos removal, it is advisable not to undertake the process yourself. Only licensed technicians possess the skills, tools and know-how that are necessary for safely removing the asbestos, sealing off the area until it can be decontaminated and contain the risks associated with the procedure.
Before you decide to undertake the actual process it is important to have the region that is to be worked on inspected by experts. There are actually two levels of inspection that you will have to undertake. The first involves having officials from an inspection company visit you and thoroughly check out the area to make an assessment of the different factors involved. The second level involves someone from the removal company inspecting the area to see what needs to be done, if there are any special measures to be taken and corresponding costs.
Costs of Asbestos Removal
It is important to understand that the average costs of asbestos removal varies from place to place. State laws governing the procedure can greatly vary and the degree of work required in your particular situation will also contribute to the overall cost. However, on an average, estimates say that doing away with approximately 10 feet of an asbestos insulation pipe faction could set you back between $400 and $700. On top of this, you should also hire a contractor for a pre and post removal inspection, which can cost around $600 to $1000. If you plan to have an asbestos removal procedure carried out on your home to include roof, walls, and flooring, the cost could run up to as much as $30,000.
