Attic Bedroom Conversion
what you'll need
- Tape Measure
- Pad and Pencil
- Window
- Cutting tools
- Drywall
- Framing lumber
- Door
- Screws
- Drywall
- Putty
- Sealing tape
- Decorating equipment
If your empty roof space is perfect for an attic bedroom, you may decide to extend your living space to accommodate one. There are many possibilities that you can design around your attic space and the first step is the careful planning of your new bedroom. There are a number of considerations including the possible inclusion of an en-suite bathroom, room for furniture and providing daylight by installing windows.
Step 1 – Planning
Take measurements of your attic space and draw up plans that suit the structure of the area. If your attic ceiling is vaulted, you will need to arrange your room to gain the least amount of lost space from the angled ceiling. If your attic does not currently contain a window, you will need to make allowances for one in the right area. You may also need to consider placing any water tanks somewhere else within the attic space. Think carefully about your staircase to the attic and how the approach will look. You will need to be able to get your furniture inside once the room has been remodeled.
Step 2 – Budgeting
Consider the materials and items you will need to construct your attic bedroom. You may encounter unforeseen problems if you do not plan your budget as accurately as possible. Make a note of all the materials and desired features. Account for structural alterations such as the addition of a casement window, a door and a staircase to reach the attic.
Step 3 – Windows
You may need to obtain planning permit before creating a window in your attic space, so check with your local planning department for any regulations regarding structural changes to your home. If you are clear to proceed, mark out where the window will go and cut the correct sized hole. Fit your casement window in place and secure it using the fittings that it came with.
Step 4 – Construction of the Frame
Your dry wall will need a frame to affix to. Using 1 inch-by-2 inch framing lumber, create a suitable frame to house your dry wall. Your roof shape will dictate the form this frame will take. You may also add insulation at this point between the new frame joists.
Step 5 – Dry Walling
Once your planning has reached its final stage, you can begin constructing your attic bedroom. First, you will need to seal the walls with dry walling. Measure the dry wall panels you need and cut them to size. Attach them with dry wall screws to the ceiling joists and create the walls of your bedroom with vertical dry wall boards. You will need to create a wooden frame so that vertical boards can have a secure placement. Use tape and putty to seal and cover the dry wall joints.
Step 6 – Assembling your Room
Once you have completed fitting the dry wall, you are now able to add your door frame and baseboards. Measure your baseboard lengths against your new wall and cut the corner miters to 45 degrees for a clean continuation. Fit the door frame and butt the baseboards up against the edge. Once your door frame is in place, you can then measure the door and hang it correctly in the gap.
Step 7 – Painting
Your room is now essentially completed and it just needs the finishing touches. Make sure the putty in the dry wall joint seals is dry. Paint the walls using your roller or brushes. You will most likely need two coats of paint on the walls.
