cancel
Job type :
Zip Code :
community forums
comments
Attic Rats: Rid Your Home of Upstairs Pets
Attic rats are more than just a nuisance in a household, they are also a potential health concern. They carry diseases, contaminate food with urine and feces and they can bite. Rats hunt for food and shelter as efficiently as any small animal, and your home provides both of these necessities, with your attic often serving as a quite and rarely-trafficked hiding place.
Step 1 - Identify Your Pest
There are two types of rat that will generally invade your attic: The Norway rat and the roof rat
The Norway rat weighs between 12 to 16 ounces and its length is 6 to 8 inches. Its brown fur is shaggy and coarse. It has small ears and eyes, a blunt nose and scaly tail. Norway rats like to use paper, grass or other soft materials to build their nests.
The roof rat weighs about 5 to 9 ounces and grows to a length of 7 to 10 inches. A pointed nose, large ears and black smooth fur are indications that you have roof rats in your attic. Roof rats prefer to nest off the ground and are found mostly in urban areas.
A female attic rat can have an average of four to seven litters a year with eight to twelve pups in each litter.
Step 2 - Determine Their Access Points
You must thoroughly search your home from the basement up to find any areas where rats are gaining entrance. Possible entry points for an attic rat are windows, door thresholds, utility lines and inlets, rooftops and downspouts.
Step 3 - Track Your Rats
Tracking the runways of an attic rat helps you find out how they are getting into your home. Sprinkle unscented baby powder or flour on suspected rat traffic areas to see the rats' runways. Also, look for droppings and smudges left from the rat’s oily fur. Attic rats can gnaw holes in wood and damage electrical wiring.
Step 4 - Seal Off the Attic
Keep in mind that rats can squeeze through a hole the size of a quarter. Use steel mesh to seal any openings, since rats can chew through wood and even concrete.
Step 5 - Set Traps
Snap traps are the most humane efficient way to get rid of rats in the attic. Rats are naturally distrustful of new things placed in their environment so you have to get them use to the traps before setting them. Leave a few unset traps out with peanut butter to make the rats feel comfortable around them. Then, after a week or so, set the traps to spring. This method allows you to trap a large percentage of the rats before they can reproduce and get scared away from the traps. Dispose of carcasses immediately.
member comments
Did-it-myself Projects
updated by gibburnz
did this on 11/23/2009
Small Kitchen Rental Upgrade
updated by Rocky1008
did this on 11/07/2009
Garage Shop Organizing
updated by dhammon
did this on 11/04/2009
The Deck
How to Build a Shoe Storage Bench
sponsored articles of the day
