Login Error
Close
Attic Renovations Made Easy
by DoItYourself Staff
Attic renovations have become popular home improvement projects as people look at unused attic space as potential bedrooms, studies or libraries, home offices or entertainment areas. Before initiating your renovation project, it is important to plan it based on the structural limitations of an attic, like its shape and structure, the height of its ceiling and the mode of access to your attic.. Once you have an effective plan to work within these confines, your attic renovation can become a smooth, enjoyable project.
Ceiling Height
The height of your ceiling will determine how much and what type of furniture your attic can accomodate. For example, spaces with lower ceilings may be ideal for closets or storage areas, while higher overheads may allow for floor lamps or entertainment centers. It is important to verify that it the ceiling height accommodates your minimum headroom requirement.
Entrance
If your attic is already accessible through a staircase, you do not have to worry about constructing a new one, though you may consider recovering the steps with carpet or staining hardwood. If a pull-down ladder is the only means of entrance, then you must determine where a staircase can be added in your home. Consider a spiral staircase to save space.
Structure
Study the existing structure of your attic to determine the load bearing capacity of its floor and ceiling joists. Consult a professional who can confirm that your attic can withstand remodeling and restructuring. This study will prevent any future problems which could be encountered due to a weak frame.
Natural Lighting
It is important that your new room receives sufficient natural light. If your attic does not have windows, then you should consider installing skylights or windows with the help of dormers.
Heating and Cooling
Attics are susceptible to seasonal variation: they get very hot in summer and very cool in winter. To maintain a desired room temperature, you should consider installing a localized heating and cooling system in your attic. This will reduce the complications involved in connecting it with the main air conditioning system of your house.
 forum activity
