Login Error
Close
Attic Storage - Keeping Storage Warm for Winter
by DoItYourself Staff
Attic storage can be a great place to store your belongings during the winter. It's out of sight, out of your way and a great way to efficiently utilize by what would otherwise be an empty space. But if you want to make sure they survive the cold winter temperatures, you will need to make sure that attic is properly insulated and adequately ventilated.
Figuring Out Your Attic Insulation Needs
First and foremost, you must check to see how much insulation your attic needs and (approximately) how much you would have to pay for it. The older the house, the less likely it is to be adequately insulated. You can look up this information at the U.S. Department of Energy's Zip Code Insulation Program website.
Once you have that figure as a starting point, you should examine your attic to see where the insulation will go. Carefully check your ceiling for exposed ceiling joists, gaps and other signs of damage. They will need to be insulated first. You should also check for the signs of moisture. It will help you find smaller leaks and alert you to the presence of mold. If you have a sloping ceiling, you will need to buy enough insulation to insulate the areas between the rafters.
Ventilation
While insulation is important, you should also make sure the attic is properly ventilated. Otherwise, the attic may become too hot, which can be just as dangerous as cold temperatures. For best results, get the automated vents - they will release cold air automatically when the attic temperature becomes too high.
 forum activity
