Login Error
Close
Automotive Air Filter
by DoItYourself Staff
An automotive air filter is a device that is used to stop dirt and debris from entering a vehicle’s motor through the carburetor.
Why an automotive air filter is important
An automotive air filter is considered a vital part in any car or truck even if it isn’t mechanical in nature. If an automotive air filter isn’t in place, dust, dirt and other particles can make their way into a vehicle’s engine and cause severe damage. For proper vehicle operation, only clean air should go through the cylinders to the engine.
Care of an automotive air filter
An automotive air filter should be changed on a regular basis. This is commonly performed along with oil changes or lube jobs. In addition to changing an automotive air filter, it is also important to make sure that a filter has no leaks. This can occur when the seal between the housing and the cartridge is not tight. To be certain leaks are not a problem, make sure to:
  • Check the cartridge – An automotive air filter should be the proper one for the vehicle in question.
  • Check for damage – It is a good idea to check the assembly in the vehicle for any signs of damage before installing an automotive air filter.
 forum activity
