cancel
Job type :
Zip Code :
community forums
comments
Bamboo Beaded Curtain Care
People tend to look at a bamboo beaded curtain as a simple form of art within your home.  When you purchase a set of these, you need to make sure that you take proper care so that your beaded curtains will last for years!
Simple Cleaning
There are microorganisms and dust all over the place, including in your own home or office.  Every once in awhile, it may be a good idea to take the time to clean these bamboo beaded curtains.  You can use a wet washcloth, or even some sort of cleaning agent, whatever you may prefer.
Deep Cleaning
If your beaded curtains are extremely dirty, a simple cleaning will not suffice.  In order to get a deep cleaning done, you will need to fill your bathtub up with about 6 inches of warm water.  You may use some light soap, depending on what you curtains are made of.  Let them soak a little bit first, for about 30 minutes, and then take a washcloth and wipe them down. You can also hang dry them outside to dry them quicker.
Check the Strings
It is always important that you ensure that the strings of your bamboo beaded curtains are not rotting.  In order to find this out, all you need to do is give the beaded strand a little bit of a tug.
member comments
Did-it-myself Projects
updated by gibburnz
did this on 11/23/2009
Small Kitchen Rental Upgrade
updated by Rocky1008
did this on 11/07/2009
Garage Shop Organizing
updated by dhammon
did this on 11/04/2009
The Deck
How to Build a Shoe Storage Bench
sponsored articles of the day
