Basement Heating: Electric Baseboard Heater Pros and Cons
Installing an electric baseboard heater in your basement could be a viable way to produce heat in the basement. However, this type of heater will carry with it some disadvantages as well. Here are a few pros and cons of using electric baseboard heaters in your basement.
Pros
Easy installation—This type of heater is extremely easy to install. You should be able to simply attach it to the baseboard area in the basement and you will have a ready source of heat. By comparison, it is one of the easiest heaters to install.
Cost—This type of heater will also be easier on your budget than other types of heaters available on the market. Therefore, this can be a good way to save when remodeling your basement.
Cons
Heat output—If you have a large basement, this may not be enough to completely heat the area. They can put out some good heat, but they are not as powerful as some of the other heaters that are available.
Efficiency—Using an electric heater is not going to be as efficient as other heaters. By comparison, a gas heater is going to be much more efficient when heating your basement. Most of the time, basements are big open areas, therefore, you do not want to spend a lot of money to heat the entire thing.
