Login Error
Close
Basement Remodeling Plans to Let in More Light
by DoItYourself Staff
When making your basement remodeling plans it can be helpful to include ideas that will help bring in more light to the room. Maximizing and increasing light sources can make a basement more functional, usable and pleasant to be in. Here are some basement remodeling and improvement tips that can help you let the light in.
Light-Colored Paint
One of the cheapest and most effective basement remodeling plans that will help to brighten up your basement is to use a bright, reflective paint. This will help to amplify the small amount of natural light that comes through the small windows in the basement.
Increase Your Wattage
Use plenty of bright lights in your basement. Lights which throw off natural UV light will also help to simulate natural lighting. Spotlights are another great option because they can be placed in ways which will help remove the shadows from the corners of a basement.
House of Mirrors
One option that can work in certain situations is the use of specialized mirror panels placed in the basement’s window wells. These panels have several variably positioned mirrors which are designed to reflect sunlight through the basement window and into the room below. When using this option it is also necessary to install a protective cover over the window well to keep dirt and other debris from getting inside the window well.
 forum activity
