cancel
Job type :
Zip Code :
community forums
comments
Answers to Basement Questions #1
Attics 1 - Attics 2 - Basements 1 - Basements 2
Q. Which basement is better: a poured wall, Styrofoam poured, or block? What is the best way to heat the basement?
A. Poured Concrete, Insulated Concrete Forms, and Concrete Block walls will all perform the same if built according to code and engineering standards. So the answer is none is 'better' unless you have a specific issue you need to address.
Basements are to be insulated and compensated for energy loss depending upon the location, type of basement exposure, local heating requirements calculated by Degree Heating days, and other issues. How one chooses to heat or cool depends upon many factors.
Q. We are finishing our basement and are almost done with the framing of all the interior walls and ceiling with drywall ceiling. I've talked to the city building department about fire blocking and still am not clear on how this is done. One stud wall is about 4 inches from the cement wall. Do I try to get up back behind the top plate and attempt to nail/screw another piece of wood in there? Will insulation work, and if so, does it have to be secured somehow?
The finished space will be five rooms and cover about 1,000 sq feet. I know I'm probably making this more difficult than it has to be, I just can't picture how we're going to be able to get up, in, back behind there. I hear that the smaller gaps can be filled with "great stuff." Will this "stuff" adhere to both the cement and the lumber?
A. Where your framed walls run perpendicular to your floor/ceiling joists above, fire blocking should be installed between the joists and above the top plate of the framed wall in the form of 2 x 10s or whatever are the dimensions of your floor joists above. In other words, you will need to cut individual blocks out of 2 x 10s at 14 1/2 inches long and fasten them between each floor joist over the framed walls. Where the framed walls run parallel to the floor joists, you can fasten a plate to the top of the framed wall and to the side of the nearest living space joist so that any fire that erupts behind a framed wall will be contained there. Alternately, you can use unface fiberglass insulation stuffed between floor joists in any location above the framed wall. Some spray foam insulations in the can, those manufacturered after January 2003, are generally fireproof and will work for smaller areas. Read the fireproofing characteristics on the can before using.
Q. I'm trying to spruce up my basement a bit. It is unfinished with a cement floor that has lots of cracks in it. Is there a way to make the floor look nicer without actually putting real flooring down?
A. Fill the cracks, etch, clean and then seal with any number of single or two and three part products available from paint vendors.
Q. My family is finally finishing the unfinished half of our basement for my bedroom. The basement bedroom is directly under the master bedroom, and as it is now, when you are downstairs you can hear everything that goes on upstairs and can hear down from up. What is the best way to soundproof the ceiling so that my wonderful parents won't be woken up when I have friends over and I won't be woken up when they get up at the crack of dawn?
A. The thicker the walls the better. For your ceiling and walls, after you frame them, be sure to insulate them. Although insulation is not the best sound barrier, be sure to add two layers of 5/8 drywall. The more rock you have, the better barrier it is. That is the cheapest way of doing it.
Q. I finished my basement a few years ago. I replaced windows, put up vapor barrier, seal and patch walls and did everything else I thought I was supposed to do. We have had a lot of rain lately and noticed a little puddle on the floor by one wall. So I thought maybe the window was the problem. I pulled off the windowsill and noticed that some plasterboard had black mold. I didn't see water but did smell mold. How can I tell if the rest of the plasterboard got wet or has mold? Should I rip the rock down and put up paneling on exterior walls?
A. It might be best to remove a strip of the drywall about 1 to 2 feet above the floor and see what you have. It's best to sample an area and determine to what extent, and how high up, you should replace drywall.
Visit our Community Forums for more answers to your home improvement questions.
© 2006 DoItYourself.com
member comments
posted Jul 01, 2008
Drywall is known to facilitate the growth of mold. It is a really bad choice for basements.
I'd consider a moisture proof wall system like the ThermalDry instead.
Did-it-myself Projects
updated by Pecos
did this on 8/15/2009
Fake Log Cabin
updated by Graham Lane
did this on 8/07/2008
A Portable Slot Car Track
updated by CharlesJ
did this on 3/28/2008
Bar / TV Room
Decorating For Thanksgiving
sponsored articles of the day
