Login Error
Close
Basic Roof Vent Flashing Installation Tips
by DoItYourself Staff
Roof vent flashing is a necessary component to your roof structure. It helps to prevent the accumulation of moisture and rain in and around the vent. Roof vent flashing is fairly easy to install. You must be comfortable with heights and getting onto the surface of your roof to perform the installation. Below are several tips you should know about roof vent flashing and the installation of the product on your roof.
Know When to Install or Repair
Do not ever let a problem get too big. You should always install or repair your roof vent flashing when you notice signs of a leak problem. For example, if you notice that there is a collection of water dripping from your roof, you should take a look at the flashing and get it repaired as quickly as possible. The general problem areas you always need to keep a watchful eye on are as follows:
  • Vents around skylights
  • Vents around chimneys
  • Vents around soil stacks
  • Vent fans in general
  • Roof valleys with venting
Each of these locations can be a problem. Keeping a watchful eye will make sure that you do not end up with major repair work.
Seek out a Professional
When in doubt, always ask a professional for their advice and their knowledge when it comes to installing roof vent flashing. You do not want to tackle this project if you do not understand some of the principles. Done wrong, and you could end up with larger problems on your hands.
Maintenance Checks
Check your flashing every time you clean the gutter system on your home. Check the flashing and the condition of the shingles around the vents.
Fasten Nails
When installing the roof vent flashing, fasten the nails properly. Cover the exposed nail heads with a little bit of roofing tar. This helps to prevent nails from popping up over the course of time due to different types of weather conditions.
Apply Caulking
Apply caulking around the edges of the flashing. This will make sure you create a good seal along the edges of the roof vent flashing.
Careful with Shingles
If you are reinstalling a new set of flashing, then be careful with the shingles. You will need to carefully lift the shingles up and put them away for safe keeping. As you finish adding the flashing, add the shingles back and properly overlap them. If you fail to overlap the shingles properly, then you may have additional water leak problems.
aint the Flashing
Newly installed flashing is usually nice and shiny in appearance. Take out paint appropriate for your roof and coat the flashing so that it matches the color of your roof shingles. First, coat the flashing with a zinc-based primer. Then add the rust preventative metal paint to the surface of the roof vent flashing. You now will have a great looking roof.
 forum activity
