Login Error
Close
Basic Tool for Grout Work
by DoItYourself Staff
Using the appropriate grout tool for executing basic deck projects, like tiling, is vital. Grouting is among the last steps for finishing a tiling project. Grouting includes filling the small spaces that exist between tiles that are often referred to tiling spaces or tiling lines. Read on to learn about the types of tools you will need for different stages of this project.
Grouting Basics
Nearly every kind of grouting material available in the market is essentially a mortar-based product. The presence of a well-laid grout ensures improved aesthetics and performance of a tiled deck. For starters, the grouted tiles are secured more firmly. Secondly, the presence of grout ensures that dust and debris isn't able to gain a foothold between the tiles.
Grout Tool Overview
A grouting project involves the usage of many techniques that are easy-to-learn and doesn’t need professional assistance. However, an important and irreplaceable aspect of grouting is the use of appropriate tools. Most of these tools are easily available and aren’t expensive. They should be looked upon as a one-time investment since grouting is part of basic repairs/maintenance of domestic surfaces.
Tools for Removing Old Grout
A chisel is perhaps the most inconspicuous grouting tool. However, it is a critical tool, highly recommended for preparing the grouting surface. Before applying new grout, it is vital to remove the old, grouting lines. This can be easily done with a chisel. A hammer is not recommended since it can damage the surrounding tiles. A chisel provides the advantage of precisely hitting upon the grout lines. Thin chisels are ideal for this purpose.
Tools for Preparing Grout
The grouting powder and water are mixed according to packaged instructions. A plastic bucket is ideal for preparing this grout-mix. A thin, margin trowel is very handy for stirring the grout to the required consistency.
Tools for Floating Grout
Floating refers to the process of pressing the grout between the fine lines of a tiled surface and removing any, excess grout. Grouting float has a typical, rectangular shape. The handle is usually made of wood and the flat, pan-like part is made of metal or rubber. The float is used for carrying the grout from the bucket on to the tiled floor.
After applying the grouting mix, it is important to press upon it to ensure that it is inserted into the fine crevices. You need a float for this purpose, too. The flat panel makes it easy to press upon the grouted lines. Due to the compression, the excess grout is squeezed out along the edges. The float is used for swiping and collecting the excess grout.
Tools for Cleaning Grout
It can be a bit tedious to collect smaller bits of the excess grout using the float. For this purpose, using a putty knife is recommended. The sharper edge of the knife makes the entire process much easier. Using the grouting float usually leads to smearing the tiled surface. The grouted surfaces need to be repeatedly cleaned to get rid of the residual grout. The tiles are best cleaned with a tiling sponge.
Tools for Sealing Grout
The grouted joints need to be sealed to make them durable and impervious to water. The sealer is available in the form of a packaged, glue-like material. It can be easily applied using a paintbrush. The excess sealer can be wiped-off with a piece of dry cloth.
 forum activity
