Login Error
Close
Basics of Micron Water Filters
by DoItYourself Staff
Just like the other one
Micron water filters are more expensive than charcoal water filters, but are more effective. They are used industrially as well as at home, and can remove many contaminants from your tap water. Micron water filters provide 99.984% reduction of 3 - 4 m particles - 99.96% reduction of 1 -2 m particles, which means that most particles will be removed from the water. This should make for better tasting water, or tasteless, however you put it, and also water that has the appearance of purity, removing all opalescence.
Cost of micron water filters
The cost of your basic micron water filters can range anywhere between $25 and 200. This apparent dichotomy is because the purpose of each filter decides the price. Some have industrial uses, and are therefore much more expensive, and others are meant solely for at-home water filtration, in which case a cheaper model is acceptable
 forum activity
