Bathroom Design Tools Needed to Redesign your Bathroom
If you are doing a remodel, then there are a few bathroom design tools that you will want to keep in mind for the project. Here are a few that you can consider.
Graph Paper
Graph paper is a big help when you are designing a new space, especially a bathroom. Because you have so many fixtures that need to be worked around, such as a toilet, sink and shower, you will want to make sure that you are designing the layout in terms of measurements. Using graph paper can help make the design more realistic. When you are making your layout with the graph paper you will not only want to include the fixtures, but also indicat where any electrical outlets are in the room or where new ones will be placed. Another thing to add to your layout would be any water lines as this is essential for many of the fixtures in the room. This step may seem like a hassle while you are doing it, but the more work that you put into planning, the less frustration and mistakes will occur when remodeling. Not only do you want to include what you will have in the room, but you will also want to make sure that you are using the correct measurements and being realistic so that you can get the job done without any disappointments or mistakes.
Tape Measure and Ruler
These two tools will be the most important when it comes to the remodeling of the bathroom so make sure to get acquainted with them from the get go. You will need to take measurements of the bathroom, the fixtures that you are putting in, the tiling, the length from certain electrical outlets and so on. The list is endless when it comes to what you will be measuring, so having a few measuring tapes and rulers handy is a great idea.
Designer Books and Programs
Many times it is much easier to see the whole picture together at once instead of small ideas that you have to put together in your mind yourself. It is hard to look at different fixtures and patterns separately and know whether or not they will go together. Now, many hardware and design stores have books or on line programs for the computer that can help you see your design put together before you even get everything set up. This will allow you to see if everything you are picking out fits together and whether or not you will like the final product. Of course you can pick out your own designs; however, seeing it together will help to get the idea of which steps to take first or if just one element of the design is off. This can potentially save you frustration and money if you begin the project and end up not liking something.
The bottom line is that these tools are necessary when doing any remodel and will help you from start to finish.
