Login Error
Close
Bathroom Faucet Repair: Stop the Dripping
by DoItYourself Staff
A simple bathroom faucet repair can save you money and benefit the environment as well. Since a leaking faucet wastes more water than you may realize, a quick repair is important.
Step 1 – Determine Faucet Type
There are at least two standard faucet types: the compression faucet, which is the older, two handle style, and a “washerless” faucet, which uses a single handle or lever to control water flow. These may be disc, ball, valve or cartridge faucets.
Step 2 – Prepare the Space and Tools
Before beginning the bathroom faucet repair, plug the sink so you won’t lose any parts. Tape the wrenches you’ll be using so you don’t mar the surface of any fixtures when you take them apart. Make sure to keep track of any pieces and take them with you to the hardware or home improvement store. There are many different kinds of faucets, and you need to get the exact replacement types. Turn off the water shutoff valve.
Step 3 - Remove Faucet Handle
Generally speaking, the leaking compression faucet handle is a result of a corroded “o” ring, rubber gasket, twine or the packing nut that holds the packing in. A leaking spout is usually the result of a leaking washer or valve seat. While the faucet is apart, replace them.
A valve faucet could be leaking as the result of a corroded “o” ring, bad cartridge, or seals.
 forum activity
