Login Error
Close
Bathroom Floor Tile Design for Bathrooms of All Shapes and Sizes
by DoItYourself Staff
When it comes to bathroom floor tile design homeowners are not locked into any specific design rules. You can design any type of tile floor that you want with a little bit of creativity and imagination. Remodeling a bathroom gives you the opportunity to not only give it a modern facelift, but also to add your own personality and flair. If you are thinking about what type of bathroom floor tile design you should incorporate, here are a few ideas that you can think about.
Solid Color Design
Many times, this is the way that a lot of people will go. It is easier to install the same type of tile color, and it may cost a little less. This design idea may seem like it is nothing exciting, but depending on the type of tile you have on the wall, an elaborate design on the floor might not fit too well. Choose the color that will match with the rest of the bathroom.
All White Design
Sometimes the most elegant of design is found in the most simplest form. A bathroom that is set off in sparkling white tile is a place where you can relax and know that everything is once again arranged in a harmonious place. White tile has received rather harsh criticism by some designers, but it is easy to clean and lends to a modern look and feel.
Mosaic Tile Design
A rather distinguishing bathroom floor tile design is one with a beautiful mosaic of colors. There does not have to be a set pattern to the color of this type of design. You can let your creativity run wild and capture your personality in the tile itself. With a mosaic type of tile design you will want to watch out for colors that are too bright or dark. This will create a look that detracts from the rest of the room and makes it unappealing. Warm colors that are blended together with three or four different colors will work best with a mosaic design. Incorporate the rest of the colors into the mosaic tile design for a great look to a bathroom.
Flagstone Tile for Odd Shapes
There are many different shapes that a bathroom can take on. The different elements (vanity, toilet, tub, shower, closet, etc.) can be configured in a multitude of ways. Because of this the floor pattern can be quite irregular. Make use of the irregularity with flagstone tiles. They tiles are not cut into the normal squares. They are eclectic in nature because there is no true shape to them. For a truly inspiring bathroom floor tile design look into the flagstone tiles.
Patterned Tile Design
Before you lay down the tile floor of your bathroom, take into account some of the patterns that you like. Choose some tiles that can be maneuvered into this pattern. Create the pattern on the floor without the use of mortar to make sure that you can easily fit around the corners and other fixtures in your bathroom. Once you have the pattern decided on, you can then use the mortar to install the tile permanently.
 forum activity
