Login Error
Close
Bathroom Tile Designs: 3 Beach Theme Ideas
by DoItYourself Staff
Incorporating a few beach ideas into your bathroom tile design is a great way to make your bathroom renovation project beautiful and unique. These beach themed designs are gaining popularity for their use of clean lines and soft, natural colors.  There are many types of tile ideas you can incorporate into your design such as subway tiles, mosaic tiles, and accent tiles.  Homeowners have the choice of selecting these tiles in either ceramic or glass. Any combination of the three will make your bathroom feel like those found at a vacation resort.
Subway Tiles
Subway tiles are a great choice for bringing a beach feel to your bathroom tile design. Their simple look and design makes them the perfect tile to compliment any bathroom layout. These tiles are named based on their resemblance to the tiles that were used in the construction of subway stations. Usually they’re 3 inches high by 5 inches wide and found in shades of gray, white and tan. When installed in a running bond type pattern they can resemble the feel of a beach bath house.  You can even add accent tiles or chair rails to enhance the design or divide a large tile wall into sections.
Mosaic Tiles
The use of mosaic tiles is another great way to bring the feeling of the beach to your bathroom tile design. These tiles are commonly found in 12 inch by 12 inch sheets and are available in a wide range of color combinations. The sheets are actually comprised of smaller tiles that are about 1 inch in size and are held together with a mesh backing. Mosaic tiles are ideal for smaller bathroom floors since once they’re installed they often make the room seem larger. These tiles are also commonly used for shower stall floors. If you’re using mosaic for your floor tile then you can also cut the mesh backing to form mosaic accent strips for your wall tile. This is an economical way to give your layout a unique look while tying the floor and wall tile together.  To really give the design the sense of the beach it’s best to stick with light tans and brown to replicate the different shades of sand.
Accent Tiles
One of the easiest ways to add a little of the beach to your bathroom tile design would be the use of accent tiles. Accent tiles are specially designed tiles that are meant to add a unique flair to your tile layout. Most tile companies that produce wall tiles will also produce accent tiles to match the different sizes they offer. These tiles can be found with either two or three dimensional images of different beach themed designs such as sea shells or sea horses. Substituting an accent tile in place of a regular wall tile will help add character to the design. Combining accent tiles and accent strips will give you endless design possibilities.
Beach themed bathroom tile designs are popular design motifs for homes located in coastal areas. By incorporating some simple beach themed ideas along with similarly themed artwork and accessories, you can create your own bathroom paradise.
 forum activity
