Bath/Shower Stall Restoration
what you'll need
- Hammer
- Prybar
- Utility knife
- Cordless drill
- Sawzall
- Channel lock pliers
- Screwdriver(s)
- Tape measure
- Safety goggles
- 1/2 inch cement board
- 1 1/2 inch graphite screws
- Ceramic tile
- Shower fixture
- Shower door
Restoring a bath shower stall can transform your old and faded stall into the ultimate bathroom paradise. But a restoration of this size requires some planning and patience as it won’t be completed in a day. With the right tools and a good game plan, you can complete this restoration with results that anyone would be proud of.
Step 1 – Remove the Old
It’s a good idea to remove all the material down to the bare studs for a fresh start. In order to speed up the process use a sawzall to remove the tile and drywall and one shot. Simply use the sawzall to cut along the horizontal grout line halfway up the wall. Make sure you hold the blade at a shallow angle so you don’t damage any plumbing pipes. Then take the hammer and prybar and rip off the wall in large sections. Make sure your wear the proper safety equipment when undertaking any demolition.
Step 2 – Install the Cement Board
Installing cement board prevents mold growth and is a great sub surface for ceramic wall tile making it a critical component in a bath shower stall. Cement board is installed using the same methods and techniques as regular drywall. Install the boards horizontally making sure the seams fall on a stud. You can use either a utility knife or a grinder to cut the cement board. Make sure you install the shower fixture body before covering the plumbing wall. Then use the cordless drill and graphite screws to secure the cement board. Locate the screws about 8 inches on center to properly secure the board.
Step 3 – Install the Tile
The ceramic tile installation is where a homeowner can really get creative with their design and customize the look of their bathroom. You can use a combination of wall tiles along with accent tiles and chair rails to create virtually any look. Once you’ve determined the layout it’s a good idea to draw it out on the wall. Then, using a wall trowel and glue, begin to install the tile working outward from the center of the wall. Work in small areas to prevent the glue from drying prematurely. When the time comes to make a cut, you can use either a wet saw or tile scorer depending on your preference.
Step 4 – Install the Fixtures
The last step in a bath shower stall renovation is to install the shower fixture and shower door. Use the channel lock pliers and screw driver to install the face plate and shower head. Make sure you follow the manufacturer’s instructions for a proper installation. To install the shower door you’ll need a cordless drill to install the tracking. Most manufacturers will provide detailed instructions and all the hardware required to complete the installation.
