Login Error
Close
Bathtub Wall Surround Removal Tips
by DoItYourself Staff
If you're planning on removing a bathtub wall surround from your bathroom, there are a few things that you'll need to keep in mind in order to ensure that the process goes smoothly. Read on for a few tips on how to avoid the most common mistakes.
Loosen the Attachments Properly
One of the most damaging things that you can do to your bathroom floor, to the bathtub and to the surround is to remove the surround from the tub system while it's still partially attached. This can cause the linoleum to strip on the floor and a variety of other problems as well. Instead, be sure to use a proper glue remover in order to loosen the attachments before you begin.
Lift the Tub Surround
If you drag the tub surround across the floor of the bathroom, you're likely to suffer some damage to the floor. Instead, you'll need to lift up the tub surround from the area around the tub. This oftentimes requires numerous people in order to operate successfully.
Shut Off the Water
Don't forget to shut off the water supply while you're making any adjustments or repairs to the bathtub or the shower system in your bathroom. This saves you from potentially dangerous or messy situations.
 forum activity
