Battery-Free Wireless Remote Light Switch: Benefits
A battery free wireless remote light switch is a wonderful, innovative device that not only saves time but money as well.
Wide Area Application
In a conventional lighting system, a light switch is fixed in one spot. A light can only be turned on and off by flicking a fixed switch. Such a system can work in small enclosed spaces, but could pose a challenge for wide areas. For example, if your light switch is located at the far end of a big room, you would have to travel a good distance just to turn the light off or on. This would waste some time and effort on your part. With a battery-free wireless remote switch, this problem would be eliminated; you can conveniently place switches in accessible areas, thus saving you time and effort. If your light is located outdoors, you can even install an extra switch indoors in case of inclement or bad weather.
Ease of Installation
Another benefit of having a battery-free wireless remote light switch is cost and speed of installation. For wired 3-way switches, you will have to spend for additional wires that connect the new switches. And since the job can be technical in nature, there is a high likelihood that you may need to hire the services of a professional to help you install the wires and switches. It is a very tedious job and may take days to complete.
On the other hand installation of a battery-free wireless remote switch requires no special skills or tools; you work with your existing wiring system and the job can be completed in minutes even by a novice technician.
Zero Operating Cost
The most obvious advantage to using a battery-free wireless remote light switch is cost of operation: zero. These types of devices are equipped with little generators that harness the energy produced when a switch is turned on or off to send radio signals to receivers, so it costs nothing to operate them. And since it does not consume any form of electrical power, it is considered environment-friendly.
Reliability
Another admirable attribute of battery-free wireless remote switches is reliability. There is zero likelihood that your unit will not work due to insufficient power; which is the case with battery-powered wireless remote switches. They are also virtually maintenance free, and last as long if not longer than conventional wired systems.
Flexibility
Another advantage of using a battery-free wireless remote light switch is flexibility. These devices can be mounted on almost any surface such as wood, plastic and cement. You can also place these in areas where they can be inconspicuous and thus maintain the beauty of your home or facility.
A battery-free wireless remote light switch offers a lot of benefits and advantages to users, and there are hardly any significant disadvantages to owning one. It is a perfect lighting complement to any home or facility, and has wide and far reaching applications.
