Login Error
Close
Belt Drive Garage Door Openers: Pros and Cons
by DoItYourself Staff
Belt drive garage door openers utilize a rubber belt to open the garage door instead of a chain or some other mechanism. As a homeowner, you will find that this type of garage door opener has several advantages and a few potential drawbacks. Here are some of the pros and cons of belt drive garage door openers.
Pros
One of the advantages of belt drive garage door openers is that is it operates more quietly than other types of door openers. This is due to the fact that the door is moved by a rubber belt instead of a chain, making it an ideal solution if the garage is in close proximity to a bedroom or other living spaces.
Cons
One of the potential disadvantages of this type of garage door opener is that it can be expensive. You will have to pay more for this kind than you would with a chain drive or a screw drive garage door opener. Because of the additional cost, many people opt for a standard chain drive model to save a bit of money.
 forum activity
