Benefits of a Car Ignition System Upgrade
Your standard car ignition system benefits from an upgrade to an electronic system. A new "smart" ignition system provides cars with more pep with each step on the gas pedal.
Less Maintenance
As no energy passes through the contacts on the points, the contacts will not wear out and need to be replaced. Cars with an electronic ignition system rarely need tune ups. The improved spark capability allows you to enjoy a faster-responding car.
Efficiency
Your car will become more efficient with a new car ignition system. The automobile will not need to use as much fuel to start and to accelerate, helping to reduce gas costs. Reduced exhaust also creates a more earth-friendly car and one with a better chance of passing a smog test.
Simple Conversion
The conversion of a car ignition system takes only 15 minutes when done by a trained mechanic and costs less than $500. You can simply take your car into any mechanic and generally have your car back the same day. Ignition kits are sold online and in car repair shops, allowing a would-be mechanic the chance to upgrade on their own.
If your car has lost its energy and needs a boost, a car ignition system upgrade may be the answer.
