Login Error
Close
Benefits of a Gas Fireplace Blower
by DoItYourself Staff
There is a debate as to whether a gas fireplace blower adds to comfort levels. Most manufacturers claim that gas fireplace heaters produce both radiant heat as well as convection heat. Radiant heat is not helped by blowers, and blowers may not help to influence the air circulation beyond the immediate vicinity of the fireplace.
Heating Efficiency and Low Cost
People concerned with energy costs and efficiency insist that the gas fireplace blower will increase heating efficiency and thus reduce costs in the long run, because comfort levels are reached quickly. Most makers of gas fireplace units will give you the option of including the blower within the fireplace unit, and this is considered a feasible option if you're looking for a gas fireplace blower. Quite a few gas fireplace owners may not even be aware that they already have a blower installed with the unit. Costs for a blower can be a factor, but compared to the price of the basic unit, this additional cost is virtually negligible.
Thermostat Reduces the Electricity Bill
One of the first things to look for when you're planning to install a blower is a model that has a built in thermostat. This will regulate your fireplace and thus reduce costs, especially if you have it set to higher levels. Environmentalists suggest that your thermostat settings should be set so that you are comfortable when wearing a jacket. A shirtsleeve comfort temperature will only increase your heating bill and use more gas.
Reduce Noise Levels
Noise levels can increase with a gas fireplace blower, but the better models have this reduced to almost a whisper. One of the comforts of a fireplace in the old days was the pleasant sound of the hiss and crackling of the wood, which made you feel even more protected, so a little noise should be more than acceptable to an average home dweller.
A gas fireplace blower moves air around the room being heated. It works more or less like a fan, by sucking in unheated air from within the room and blowing it out through the fireplace. The throw of the blower is generally limited to the capacity of the blower, but high capacity blowers will increase noise levels and may even cause uneven heating in a room. You must ensure that furniture around the fireplace does not limit the blower to heat only areas around the fireplace, as this may cause you to need additional heat if you're seated further away, thus increasing your heating bills.
Increase Comfort Level in the Room
Blowers and fireplace grates can be combined, and a number of gas fireplaces have such models where the grate is made up of hollow pipes. Once the fireplace is lit, the air within the hollow pipes of the grate are also heated up. The blower is used to blow them into the room and circulate the heat. Electric points are a must for a blower, and care has to be taken to see that the wiring is done with materials that remain unaffected by heat.
A gas fireplace blower can increase the comfort levels in a room, and with an attached thermostat can automatically control the usage of energy.
 forum activity
