Login Error
Close
Benefits Of A Ventless Compact Washer Dryer Combo
by DoItYourself Staff
A ventless compact washer dryer combo is an excellent laundry solution for small spaces can’t accommodate a standard-sized washer and dryer as well as for spaces that don’t have the venting necessary for heat-based dryers.
Energy Efficient
Compact washer dryer combos save both water and electricity making them extremely energy efficient. Since the tub is front-loading the water doesn’t have to fill up to the top before starting the wash cycle. Combo units also use a standard 110V plug, eliminating the need for an additional electrical outlet, another energy-saving feature.
Single Tub, Single Load
The single tub feature means that washing and drying take place in the same chamber or tub, allowing you to go from one to the other without changing loads or settings.
No Venting Required
In combo units, the clothes are dried through a moisture condensation process in which the water is condensed and flows down a drain. Unlike a dryer that uses heat to dry the clothes, no venting is required in combo units.
While loads are small and the drying cycle takes a little longer, a ventless compact washer dryer combo is a practical laundry solution for small homes, RVs, boats, apartments, shops or any other area where space is limited or venting is unavailable.
 forum activity
