Login Error
Close
Benefits of Using a Smooth-Top Electric Stove
by DoItYourself Staff
The electric stove continues to be a popular cooking appliance in many kitchens. Various different models of electric cook tops are available on the market. One model that has had a strong impact is the smooth-top cooking range with burners built directly into the cook top. Below are 5 benefits of using a smooth top stove.
Efficient Heat Distribution
Smooth top stoves deliver a higher amount of energy to the cooking pot because of the wide, compact solid surface. More of the pot is in touch with the cook top which creates better distribution of heat to the cooking vessel. Heat is distributed more evenly to the pots which results in better cooking of food. Once the burner is hot, it avails much more heat to the pot than the traditional electric coils. This speeds up cooking as well as warming time for your dishes.
Maintenance
Smooth top cooking ranges are easier to clean due to the flat cooking surface. Clearing away spills and food droppings that occur during cooking is a much easier task as they’re all found on the cook top surface. Simply clean with a sponge then wipe away. Since the smooth top range doesn’t have a pan underneath the burners like the traditional coil cook tops, you are spared from having to clean the pan as well as cook top. This saves time during regular cleaning.
Maintains Heat after Switched Off
Once switched off, the smooth cook top maintains heat for a considerable period. Although it may seem like a disadvantage, this aspect of the smooth cook top can turn out to be an energy saving aspect once you master the technique. You may sometimes have to prepare certain dishes which turn out best when left to cook on low or reducing heat once maximum heat has been attained. Rice and stews turn out very well if left to cook on reducing heat that gradually fizzles out. It helps tenderize the dish and adds to the flavor. The smooth cook top is perfect for such dishes.
Durable
Unlike the traditional electric coils that have a high wear and tear rate, the smooth cook top is more durable. The burners do not chip, flake or crack easily. The solid nature of the burners also makes them less susceptible to deforming with time. Traditional electric coils tend to lose the flat alignment with time due to frequent usage and stress from cooking vessels. The high resilience of the flat burners equips them better to bear even heavy pots without being subjected to stress. You can enjoy doing heavy cooking without worrying about the bearing capacity of your cook top burners.
Doubles as a Storage Counter
When not in use, the cook top can conveniently serve as a counter. You can place items on the cook top if the kitchen has a lot of activity going on and you run out of counter space. This helps maintain a more organized kitchen which is always a pleasure to work in.
 forum activity
