Benefits of Using an Air Impact Wrench
If you undertake a significant amount of construction work or want to make do it yourself projects easier, you may consider adding an air impact wrench to your tool cabinet. Knowing the benefits it can offer you will help you decide whether it will prove a worthwhile purchase.
Power Supply
There are various ways in which an air impact wrench can be powered, enabling you to opt for one that is most convenient for you. Compressed air is most often used to power the tool, which will make it cheap to run, but there are also electric and hydraulic varieties available. The latter types will allow you to obtain a cordless impact wrench if a corded type hinders your movement.
Size
The various sizes in which an air impact wrench can be found will ensure that one can be found that is suitable for the project you are undertaking. Grip size is important as this plays a large part in determining whether you are able to hold it properly; it will be possible to find one that you are able to hold comfortably. All the socket sizes that can be found as part of a standard wrench set will be available for the tool, ensuring your ability to complete any job.
Ability
The manner in which an air impact wrench works will reduce the force that you will need when you are using it as the tool does all the work. The energy stored within the tool is enough to produce a great amount of pressure, which is transferred to the shaft to make the tool work. Not only does it provide a torque action, it forces the fastener forward in the same way that a hammer would to enable it to be inserted and secured at the same time. This will make the task much easier than it would be if the work was being undertaken by hand. It is a tool that can be used for assembly projects as well as those that have an element of disassembly. With some examples of the air tool, adjustments can be made to amend it so that it provides a suitable torque for the project.
Processes
An air impact wrench can be used for a range of different projects, from motor vehicle repair to the construction and maintenance of commercial machinery. The type of work that is being undertaken will determine the way in which the wrench is powered, for example, a hydraulic air wrench is best suited to heavy construction work. By contrast, a low voltage air mains-powered air wrench is ideal for minor automobile work.
Availability
Due to the wide availability of this particular air tool, it will be easy to locate replacement parts if and when they are needed. Similarly, it will be easy to find a mechanic who can effect a repair if it develops a fault. Different electrical goods brands will have their own version of the tool, allowing you some choice in respect of a trusted or well-known manufacturer.
