Best Applications for Aluminum Corrugated Steel Siding
Corrugated steel siding is becoming more popular each year. At one point it was primarily used for farms and ranches, but the stability of this inexpensive building material has caught the eye of many other industries.
Common Uses
Corrugated steel is often found on large warehouses, barns, garages,silos, and even airplane hangars. The sturdy material is easy to install and can be done in just a matter of days. The steel material will protect against high winds, hail, rain and snow, and is virtually dent proof. It's also not uncommon to find factory type buildings made of this material. It can be withstand standard HVAC systems, and is sound enough to allow for people inside the structure working for long periods of time.
Homes and Offices
While it hasn't been common to see homes or office buildings made of aluminum corrugated steel, it's becoming a more popular choice. Aluminum corrugated siding is a green building material. It has no toxic properties, and is recycle-able. Since the aluminum will reflect heat, keeping a home cool in the summer is very easy. It will also last much longer than other types of siding. Some people have reported the siding can last in excess of 50 years. It's becoming more common to see homes and offices built with corrugated steel in coastal regions. Aluminum reacts with the salt and moisture in the air to form aluminum oxide. The reaction creates a type of coating that seals the surface, preventing further damage. This type of siding can be found in numerous colors, and when installed correctly, can give any home a great 'retro' look.
Things to Keep in Mind
While aluminum corrugated siding has many benefits, there are also a few things that can make it less than ideal. With proper planning, most of this can be overcome.
Corrugated siding doesn't provide a great source of insulation. While it will deflect heat, it can become a nuisance during windy, dark, or cold weather. To combat this, proper insulation should be used inside the structure before walls are hung. Using an insulating caulk or spray foam in between the aluminum sheets will also help make this less of a headache.
If you have an older home that isn't grounded, aluminum corrugated siding is not a good choice, unless you are willing to put in the effort to ground the structure.
While it is a more green building material, it still requires quite a bit of energy to manufacture. For those who are going to extreme lengths to keep their construction green, this may not be the best option. If you expect the structure to be around for a very long time, then it can be worth the extra energy consumption.
Corrugated aluminum is also commonly found used for roofing material. If you are going to go through the time and expense of adding this as siding, it would be worth the energy to look in to the roofing options as well.
