Best Base Surfaces for Laying Epoxy Flooring
For a tough, long lasting floor, epoxy flooring is one of the most popular choices. It can be installed on a variety of base surface floors because it has very strong adhesive properties. It is resistant to dirt and grime and it is waterproof. It can be cleaned with normal household floor cleaners because it is resistant to chemicals. The surface of epoxy flooring can also be buffed with commercial buffers. Listed below are the best surfaces for epoxy flooring.
Concrete
Epoxy flooring is most commonly used on concrete floors. From residential garages to air plane hangers, epoxy flooring is the best choice for concrete. Epoxy flooring will stand up to the high traffic with no problem. Epoxy flooring not only protects your concrete from damage, you can use it to decorate or give instructions. Use different colored epoxy flooring to create walkways, arrows, or even put a company logo or design right in the floor. Make sure you prepare your concrete floor correctly before installing the epoxy flooring for the best results.
Wood
Epoxy paint is used to glue, seal, and paint wooden boats. If epoxy paint can withstand an ocean or a lake, it can certainly stand up to wear and tear on your wood floors. Colored paint can be used to paint your floor a certain color. Just like with concrete flooring, you can use epoxy flooring to decorate and design. If you would rather bring out the natural finish of your wood floors, use a clear epoxy flooring. The clear flooring creates a beautiful lustrous floor that will last for years.
Tile
Epoxy flooring can be used to cover outdated floor tile. If you’re tired of that avocado green or burnt orange and need a low-cost solution, epoxy flooring is the way to go. Make sure to use a water based epoxy paint. It has virtually no odor and is best for inside projects. Ceramic tile has a naturally glossy and slick surface. Even though epoxy flooring has strong adhesive properties, you must prepare the tile by sanding it so the epoxy will stick to it.
VCT (Vinyl Composite Tile)
VCT is basically vinyl flooring. Epoxy flooring is a good solution to changing this floor base. If you have ever moved something and it got caught on your vinyl and ripped it, you might want to consider installing epoxy flooring. It changes your vinyl into a tough tear resistant surface. Just like ceramic tile, you would want to use a water-based epoxy paint. Like ceramic tile, because vinyl has a slick waxy surface, you will need to sand it so the epoxy will stick to it.
As you can see, epoxy flooring can be installed on very different types of floors with the same beautiful results. As with any project, the proper preparation must always be done to ensure your epoxy flooring will be installed correctly. Make sure you read the directions on the flooring before you begin. Happy installing.
