The Best Garage Floor Paint For You
The first step in choosing garage floor paint is to understand that cutting costs by using cheap paint is not an efficient use of your time. Better to buy the best paint you can than spend the same amount of time applying cheap paint that will have to be covered in no time.
If you are looking for expert advice on what type of garage floor paint to use, your local hardware store or concrete contractor would be helpful. This is especially true if there is anything about the floor or the stains that is out of the ordinary.
Because it is made of a durable, high-solids 2-part water-based epoxy, one coat of epoxy garage floor paint will yield a beautiful semi-gloss finish that lasts for years. This paint is low-odor and will prevent hot tire pick-up.
Discuss with a store clerk or read the directions carefully for proper application. Some epoxies may not be applied over sealed floors. Knowing this abut garage floor paint saves time, money, and possibly your garage floor.
