Best Type of Drill Tile Bit to Use
A drill tile bit is a special drill bit needed to drill into ceramic tile. Using the wrong drill bit in ceramic tile can cause the drill to smoke. To drill into ceramic tile will require a slow speed along with the correct drill bit, otherwise it can shatter. When drilling ceramic tile, you never want to drill at a high speed. There are a couple of drill bits recommended for drilling into ceramic tile.
Carbide Drill Bit
A carbide drill bit is one of the best bits to drill into ceramic tile. A drill with a variable speed trigger will need to be used. A carbide drill bit punctures using a cone shaped hole. The carbide drill bits are to be used with less pressure. Applying too much pressure on the ceramic tile can cause it to still shatter.
Diamond Drill Bit
Diamond drill bits are special bits that have a diamond tip. They have to be kept cool with cutting oil. To use these tips, you must drill slowly which will lessen the amount of heat buildup. The drill cuts using a cone shaped hole. Large holes can be made using a larger diamond drill bit. A pilot bit is used to start the larger hole.
